CDM1250 Loud Beeps
BLS501
Tunkhannock, PA
I have a new to me CDM1250 and the beeps are incredibly loud, vs the RX audio. I do have the "Alert Tone Offset" set to -50, but the key tones and priority scan alert tones are still super loud. Is there any other way to turn them down, instead of turning them off? Thanks.
Skypilot007
Medford, NJ
I have a CDM1550 VHF radio with the same issue. Changing the alert tone offset on other CDM 1550's and 1250's I have does increase and decrease the button beep volume but this one 1550 does not respond to this adjustment, the tones are very loud. I opted to disable the tones on that particular radio. All my other warris radios are UHF and 220MHz and they all function normal.
BLS501
Tunkhannock, PA
What's the firmware in the CDM that doesn't acknowledge the alert tone volume offset... Maybe it's a firmware issue, and could potentially be what's happening to mine?
Skypilot007
Medford, NJ
R05.02.03. All my other radios have newer firmware and seem to work correctly so perhaps it is a firmware issue.
BLS501
Tunkhannock, PA
Doh. having so many different Motorola radios and how each of them are completely different from series to series, if you turn Ind Alert on, it will then use the Audio Alert Offset. Hope this helps whomever comes across this thread.
Skypilot007
Medford, NJ
Which menu is that in? I can't seem to find Ind Alert. I'm looking under the alert tones tab in the radio configuration.
BLS501
Tunkhannock, PA
Well you can do it from the radio itself if you have Audio/Tones available in your menu and go into Alert Volume Level, it'll come up with Ind Alert on/off. but in the Software it's under Radio Configuration, Alert Tones, and Alert Tone Fixed Volume.. I believe.
