CDM1250 Model Number
MDM38
I am looking at purchasing a CDM1250. The model number is AAM25SKD9PW2AN. According to the model chart on Repeater-Builder.com, the PW indicates that the protocol is 1.5ppm stability UHF only. What does this mean exactly? I only need to program conventional analog frequencies, but want to make sure this will not prevent that. All of the other CDMs I have are AA (conventional) for the protocol part of the model number.
Solution
Stability is a measure of allowable frequency drift, or the difference in frequency between what the radio is programmed to and what is actually transmitted.
The 1.5 ppm (parts per million) stability is an upgrade to the standard 2.5 ppm stability specified for the standard (AA) CDM1250 version. You won't notice any difference in programming or capabilities with the PW version compared to the standard version.
FCC rules (90.213) for UHF radios specify a maximum of 2.5 ppm drift allowed for mobile radios. If a mobile radio is used as a base or control station then the maximum drift allowed is tightened to only 1.5 ppm. This is the reason Motorola offers this higher performance model, to comply with FCC rules when using a CDM in a...
kf8yk
FCC rules (90.213) for UHF radios specify a maximum of 2.5 ppm drift allowed for mobile radios. If a mobile radio is used as a base or control station then the maximum drift allowed is tightened to only 1.5 ppm. This is the reason Motorola offers this higher performance model, to comply with FCC rules when using a CDM in a base, repeater or control station configuration.
Solution
MDM38
Thank you for the clarification! That is exactly what I needed.
