eportel6607
Hi guys,
I have two lowband 42-50 CDM1250s. The code plug is cloned the only different being the PTT ID number.
The hi power limit is 67 watts and the low power limit is 35 watts.
When I hook one up to a bird watt meter it's only transmitting 15 watts on frequencies in th lower part of it's range (around 42-43Mhz) and on channels that are higher in frequency (around 46-48Mhz) it transmits about 25-30 watts.
All channels are set to high power.
When I switch the meter onto the other radio with the same list of frequencies the meter show a transmit power of about 65 watts on everything channel.
Does anybody have any input ast to what would cause this problem?
Thanks,
C
Thanks,
C
