CDM1550 and HT1250 Emergency Question
Floridarailfanning
East Tennessee
After digging through a few more of the sample codeplugs I believe I've found it.
Signaling Configuration > Emergency > "Ack Alert"
The original codeplug I was looking at did not even have an "Emergency" tab listed under Signaling Config.
jghqaltga5926
Pineville
I believe it supports MDC signaling, or at least decoding, because it does identify the radio when it keys up.
Is it possible that it can do that, but not send an alert acknowledgment.
K2NEC
That might be it, but, on my CDM I have an "emergency" test channel that is supposed to do what he is describing and the "Emergency Type" is set to disabled. But it does ack the radio in emergency. I forget if that box is checked or not but it is grayed out since the emergency is disabled.
jghqaltga5926
Pineville
To go with along with what you’re saying K2NEC, I have the emergency tab on the CDM disabled, but I don’t recall if ack alarm is checked or not. Is this where the box needs to be checked to ensure the radio knows it needs to ack an alarm?
I thought that tab was only for the CDM’s emergency alert not dealing which how it handles outside alerts but I may be mislead.
K2NEC
That's what I thought so too. Play around with that it may be it. Worth a try
jghqaltga5926
Pineville
That’s the plan this afternoon, but I was hoping to have a better idea of what exactly I need to verify is checked or programmed. I will verify that ack radio is checked on the CDM, but it seems like I’ve done this and didn’t get the results I was hoping for.
