CDM1550 Conventional Channels
wb5nia
Brownfield, Tx
I have a CDM1550, model AAM25RKF9DU5AN. The model number says it is 128 channel, but my programmer says he can only get 16 conventional channels in it. Is the model number wrong, or is there a "trick" to program more than 16 channels?
Hiding in a coffee shop.
The "DU" in the model number says it's an LTR radio, and I'm pretty sure those only have 16 conventional channels.
I've seen guys on e-Bay that will swap out whatever IC is in the radio that makes it the LTR radio to give you all 128 channels of conventional personalities.
The conventional models will have "AA" in place of the "DU".
Tech792
Central NJ
The last 3 characters "5AN" is 16 channel........the 160 channel ends in a "6AN" if I remember correctly.
