CDM1550 - LTR PassPort for RX Only?
RadioDitch
Field Operations Member
Earth
Greetings all...
I was given a /\/\otorola CDM1550 of the 200MHz species this past week. The transmit doesn't work, and that's fine...I don't really need it to. I have an idea for it, but I need to know if it's possible first.
Could this radio this radio be programmed for a LTR PassPort system and used for receive only? Or is that impossible if it's not part of the said radio system.
Again, I cannot emphasize enough...the transmit is busted, an I have no intentions of fixing it. Just want to use it for receive only...if possible for an LTR PassPort system.
Thanks guys/gals...
62Truck
Ordinary Subscriber
Uranus
On a regular LTR system yes. On a PassPort System No. In order to get it to RX on a PassPort system the system controller would have to have the ESN programmed in it to allow it access to the system.
RadioDitch
Earth
Oh well...so much for that concept. Thanks!
62Truck
Ordinary Subscriber
Uranus
The only other way is to listen to the system in conventional mode, but you end up hearing every one who uses the system.
RadioDitch
Earth
Yeah, true. I contacted another RR member who designed a system for listening to PassPort. Waiting to see what he says. His system works great.
