CDM1550ls+ power on issue
W1CRN
Liberty, SC
I have a CDM1550ls+ that we tried to set to follow ignition only. Well that turned out to be a real bad idea. Now we can not get it to turn out at all. Does anyone have any ideas to get this thing to power back on so that we can change it back to on/off and ignition?
motomeso
Ontario
Are you using the proper pin on the accessory jack (pin 10) ? I don't know of any other was to turn it back on when programmed for ignition only. Another trick is a jumper between pin 7 and 9 with power applied to the power jack.
+12v to pin 10 should power it on, you'll have to leave it connected until you are done re-programming it. If you drop the 12v on that pin, the radio will immediately power off. I've set all mine up to use ignition switch and the power switch. Keeps this sort of stuff from happening.
W1CRN
Liberty, SC
Yes i am using pin 10 for the ignition. I tried jumpering pin 7 & 9 with power and it shorts my power supply out. Do you mean jumper the 2 pin (7&9) and power pin 10?
W1CRN
Liberty, SC
Yeah I have made sure that everything is connected and stays connected but it will not do anything. I hope that I do not have a paper wieght.
motomeso
Ontario
Just a jumper between pin 7 and 9 on the 16 pin accessory jack with power applied to the power plug of the radio.
W1CRN
Liberty, SC
Ok I got it by jumpering pins 7 & 9 and powering pin 10. you then have to read the radio and then write it with the on/off & ignition then power it on and it should work.
