cdm1550ls+
siren134
North New Jersey
Two quick questions. I just ordered a cdm1550ls+ from ebay model # AAM25SKF90PSAN, and was looking to get a breakdown of the model #. Not much luck from batlabs. And need to know if it will do more then 16 conventional channels if no trunking channels are used. Like th ex600ls+.
Thanks for your help.
SD70MAC
NC
Cdm1550ls
It can be made to do more than 16 channels with Lab tool ,thats the only way it will work.
APX8000
Sarcastic Member
AES-256 secured
Check that model number. It should be something like AAM25SKF9DP5AN. That's why batlabs isn't working for you.
If that is your model number, it should be UHF 450-520 MHz, 40 watts. However, the 5AN will only do 16 channels on the LS+ model. You need a 6AN for 160 conventional channels.
Here's a breadown of the LS+ models:
_____________________________________________________________
CDM1550 LS+ 700 MHZ 16 CH 1-15 W 12.5/20/25 KHZ AAM255HF4DP5AN
CDM1550 LS+ 136-174 MHZ 16 CH 1-25W 12.5/20/25 KHZ AAM25KHF9DP5AN
CDM1550 LS+ 136-174 MHZ 160 CH 1-25W 12.5/20/25 KHZ AAM25KHF9DP6AN
CDM1550 LS+ 136-174 MHZ 16CH 25-45W 12.5/20/25 KHZ AAM25KKF9DP5AN
CDM1550 LS+ 136-174 MHZ 160 CH 25-45W 12.5/20/25 KHZ AAM25KKF9DP6AN
CDM1550 LS+ 200 MHZ 16 CH 1-25W 12.5/20/25 KHZ AAM25MHF4DP5AN
CDM1550 LS+ 403-470 MHZ 16 CH 1-25W 12.5/20/25 KHZ AAM25RHF9DP5AN
CDM1550 LS+ 403-470 MHZ 16 CH 25-40W 12.5/20/25 KHZ AAM25RKF9DP5AN
CDM1550 LS+ 403-470 MHZ 160 CH 25-40W 12.5/20/25 KHZ AAM25RKF9DP6AN
CDM1550 LS+ 450-512 MHZ 16 CH 1-25W 12.5/20/25 KHZ AAM25SHF9DP5AN
CDM1550 LS+ 450-512 MHZ 160 CH 1-25W 12.5/20/25 KHZ AAM25SHF9DP6AN
CDM1550 LS+ 450-512 MHZ 16 CH 25-40W 12.5/20/25 KHZ AAM25SKF9DP5AN
CDM1550 LS+ 450-512 MHZ 160 CH 25-40W 12.5/20/25 KHZ AAM25SKF9DP6AN
CDM1550 LS+ 403-470 MHZ 160 CH 1-25W 12.5/20/25 KHZ AAM25RHF9DP6AN
