Cdm750 question
piper451
Binghamton, NY
I'm wondering if someone could explain to me how to reset all settings on a vhf cdm750 back to factory settings. Thanks.
piper451
Binghamton, NY
I'm having issues with. It's half of a repeater that I'm putting together. It was working fine with the exception of an mdc issue. I was switching some settings in the software in an attempt to fix the signaling problem and now I'm not getting any audio through the repeater. It's transmitting, just no audio. I figured if I start from square one with factory settings, I might be able to figure this whole thing out.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
If you will look in Program Files where your CPS resides, you will find a sub-folder entitled Samples. In there you will find sample codeplugs for every possible model number of Pro Series radios. Locate your EXACT MODEL NUMBER and TANAPA. Load that codeplug into the CPS and blow it into the radio.
As I have told a number of people already about this issue, "The answer you seek is in your own computer, Grasshopper."
cmdrwill
So Cali
The reason you saved the original 'codeplug' from your radio before ANY changes.......
piper451
Binghamton, NY
The radio was used when I acquired it and the settings had already been messed with. But thank you for your comment commander obvious.
piper451
Binghamton, NY
Steve - thank you for your useful input, I found the file and everything is working great now.
