CE-31 and windows 7
62Truck
Ordinary Subscriber
Uranus
I've done some searching and cant seem to come up with any thing....
Recently I installed CE-31 onto my windows 7 laptop just to see if it would work, and it kinda does. I am able to read the radio just fine but when I try and write back to the radio after turning the radio on and off it says programming error. I am using an actual vertex programming cable using a serial to USB adapter and I am using comport 4.
KC2EQ
Elmira, NY
Vertex programing
I have an older version (CE52) which gave me fits until i changed com port. it seems that if it reads the radio ok it should program it OK, on the same serial port settings. My cable is a serial DB-9 that is running through a USB to DB9 dongle or adapter. My problem is changing the frequencies on my VX-3200 UHF
Good luck on finding your solution
