CE-59 Dealer Mode
K3500_454
Does anybody know how to get the CE-59 software into dealer/manufacture mode? I've tried the -m, -d, ... at the end of the target line in the shortcut to the program but it wouldn't work. If it helps any, I'm using VSN 4.05 straight from Vertex Standard. Thanks in advance.
73,
Paul
n000765
CE-59 target line switch
Some Vertex software uses -manu as the target line switch. Try using that instead of -m. If it works, the password is probably ansho-bango.
There are some other possible switches and passwords discussed on the MaxKelley.com website.
As a last resort, you can open the code plug file (default.C59) with a hex editor and look for the switch and password. They are usually located somewhere near the beginning of the file.
cabletech
Puget Sound
Why do you need to attempt to get into 'dealer' mode?
Every thing you need to program a radio is open access in the program.
K3500_454
Why I want to do so is not the issue here...but if you must know, I'm trying to get the radio to work down on the 70cm ham band.
Ohhhh, and thanks to n000765 for your reply; I've already tried all the target line switches but nothing works. I'll try editing the file with a hex editor next.
cabletech
Puget Sound
One of the main things to remember about a lot of the newer radios is that if you are trying to program them more then 1 or 2 mhz out of band, then they not go that far.
This is a function of the master processor which is hard coded.
What radio and band split are you working with?
