Central Michigan Feed broadcasting
For the next couple of weeks i am in between my normal location doing some camping so with the same ch's in my scanner i am able to get Traverse City Fire 154.325 which is Gladwin's fire ch and you will hear a lot of talk from the USCG i am able to pick up Air Station Traverse City and Sector Lake Michigan East.
Also due to the area Kalkaska County fire can be listened to i know there is a feed already for that but they use the same fire ch as Clare County.
If you tried to listen this weekend the feed was up and down a lot i have fixed the probs causing it to go off the air.
I have added Traverse City Fire and Traverse City PD to the feed going to get 1 of my antennas off my house roof to cover ther rest of the feed area so things will come in clear as of right now you should hear the USCG Traverse City Fire/PD Kalkaska County Fire/Clare county Fire since there on the same ch.
Will try to have the other antenna up with in a week right now i am using a railcom magnet mount antenna.
The feed will no longer cover Clare/Gladwin/Osecola counties i am no longer in the area.
The feed will now just cover Kalkaska County Fire and all of Grand traverse county for Police and Fire along with the USCG.
Priorty ch,s for the feed will be Fire and USCG ch,s.
E-Man
Banned
Global
I did not notice the air band in your description for your Clare feed?, Yesterday around 6PM in the MT Pleasant area, I had a friend that had engine problems in his Cessna 172 and had to place a MAYDAY. I have been searching the archives, hoping to find the comms for this event. So far no luck.
