fmon
Silent Key Jan. 14, 2012
860-861 is the range which will be lost if not replaced or wavered. Stewartsville apparently ask and received new freqs rather then waver the 860 range. This range is not in the 15MHz drop as that would place them at 845.xxxx. The waver likely has limits on length of use.Unlikely those are rebanded freqs - they're ony 4 mhz down from the original (if they were rebanded, the difference would be 15 Mhz), and are not originally in the 866-869 mhz region. More likely you simply found a couple more channels for the site. If they aren't on the database, please submit them.
73 Mike
My city has two freqs in this range and have a waver approved until sometime this fall.
