- Joined
- Dec 6, 2023
- Messages
- 16
Drove by 8 today. Rescue 8 and Ladder 8 are back at 8 Station. 33 and 29 are back to single Engines.
I don’t know much about air/SCBA refill systems, so please someone chime in if they know more!L also wraps for any air support rig. According to CFD's Chief Mechanic once A/L 4 is gone, it's over. It might be the same case for HRS 2 once it's retired.
Looks like they have shifted away from making the Rescues into AerialsI found this tender for new Engines and Rescues…
Alberta Purchasing Connection
vendor.purchasingconnection.ca
So the High Rise and Air Light both have refill capabilities, but they are never used. The thought was to have a truck that could refill bottles on scene, as opposed to driving to a station somewhere else.I found this tender for new Engines and Rescues…
It seems it would be cheaper for CFD to go with couple smaller or even similar sized truck to A/L 4 that does not have a re-fill compressor or breathable refill tanks on board.
A few reasons for this; upkeep/maintenace of the system (multiple contracts have gone out over the years to keep HRS 2 and A/L 4’s air system in tip top shape so they can stay in front line service) regulations around refilling SCBA’s, renting/delivering of air tanks and down time changing them out (are the tanks kept on top of the truck? Do they have to be changed out at the shop with a crane?) — overall, more time and money having a portable system then having a system in say a fire station or central building.
Most fire departments in Canada (Toronto included) and some major FD’s in the US like FDNY use a system of trucks that carry multiple SCBA’s and when those SCBA’s are used they take them back to a central building and refill them.
I don’t know how many SCBA bottle refill stations are located in CFD stations, but to me the small truck/central refill station makes more sense if we’re talking about cost
A few reasons for this; up keep/ Maintenace of the system (multiple contracts have gone out over the years to keep HRS 2 and A/L 4’s air system in tip top shape so they can stay in front line service) regulations around refilling SCBA’s, renting/delivering of air tanks and down time changing them out (are the tanks kept on top of the truck? Do they have to be changed out at the shop with a crane?) — overall, more time and money having a portable system then having a system in say a fire station or central building.
Do the current High Rise and Air/Light units not have a cascade bottle fill system for SCBAs, before the onboard compressor needs to be used?So the High Rise and Air Light both have refill capabilities, but they are never used. The thought was to have a truck that could refill bottles on scene, as opposed to driving to a station somewhere else. The issue is that the air around the truck on scene is almost never good enough to put into SCBA bottles, especially at fire scenes, so they never got used. They might even be deactivated now, not sure. Now that the new Ladders have carry 24 bottles (I think), and rescues also carry 16 or so, so at a fire scene the Air Light/High Rise usually only provides tables and chairs for a rehab area. Calgary has 3 SCBA refill station, one at Training, one at the Shop and one at HQ. CFD wants to move to pre-stocked SCBA in pods, and run those to major events if it’s bigger then the Ladder/Rescue can handle. However, if 43 or 44 get a major fire, that POD truck would have quite the run, and is too tall to take some roads, so not sure how viable that option is.
They do. But as CFF explained, they aren't utilized as these machines suck in all the air around them at the fire scene. The downside of this is that on a fire scene the thing that is usually in the air the most is smoke. So basically you would be filling up the one thing that protects a FF from smoke with smoke. So they aren't used.Do the current High Rise and Air/Light units not have a cascade bottle fill system for SCBAs, before the onboard compressor needs to be used?
I don’t believe air around the truck is sucked in, it should be more of a bottle/cylinder fed system. Think more of air liquid/air gas company. That is what a cascade system is. All the Rescues in the fleet have this system, the bottle is stored on top of the truck in a compartment and I think is switched out at the shops - HRS2 and A/L 4 should be the sameThey do. But as CFF explained, they aren't utilized as these machines suck in all the air around them at the fire scene. The downside of this is that on a fire scene the thing that is usually in the air the most is smoke. So basically you would be filling up the one thing that protects a FF from smoke with smoke. So they aren't used.
I didn’t even think about the Ladders having bottles lol. If CFD sticks with the system, they will need a truck or the current supplies truck to switch out bottles at stations oftenSo the High Rise and Air Light both have refill capabilities, but they are never used. The thought was to have a truck that could refill bottles on scene, as opposed to driving to a station somewhere else. The issue is that the air around the truck on scene is almost never good enough to put into SCBA bottles, especially at fire scenes, so they never got used. They might even be deactivated now, not sure. Now that the new Ladders have carry 24 bottles (I think), and rescues also carry 16 or so, so at a fire scene the Air Light/High Rise usually only provides tables and chairs for a rehab area. Calgary has 3 SCBA refill station, one at Training, one at the Shop and one at HQ. CFD wants to move to pre-stocked SCBA in pods, and run those to major events if it’s bigger then the Ladder/Rescue can handle. However, if 43 or 44 get a major fire, that POD truck would have quite the run, and is too tall to take some roads, so not sure how viable that option is.
They do. They also hold 40+ SCBA bottles each (I forget the exact number on the HRS, I don’t know the number on the A/L) The compressor is part of the cascade systemDo the current High Rise and Air/Light units not have a cascade bottle fill system for SCBAs, before the onboard compressor needs to be used?
I’d be shocked if we order any more Rescues, as there’s already been hiring for filling 4 man Ladder positions while phasing out Rescues. I heard we are getting 6 new Rescues (4 TRT, 2 TRS) and maybe another 3 Hazmats, as the old ones are already 7 years old.They do. But as CFF explained, they aren't utilized as these machines suck in all the air around them at the fire scene. The downside of this is that on a fire scene the thing that is usually in the air the most is smoke. So basically you would be filling up the one thing that protects a FF from smoke with smoke. So they aren't used.
The new RFP might of been the one I mentioned a few weeks ago. Really interesting details. CFD intends to purchase 5 engines every 9 years bringing the amount to a grand total of 45 engines. CFD might also purchase a total of 10-20 rescues over the life of this contract which strikes me as odd because wasn't CFD supposed to phase out the rescues? I would imagine it would be for Tech Rescues but it says 10-20. Maybe CFD is scrapping the plan to phase out rescues and stack more halls up with rescues? Once a contract has been awarded CFD will order first order 5 engines that will arrive in the next 2 years.
This RFP does seem to be seperate from the RFP put up in March for 4 lease engines. Those seem to be engines that are needed in a hurry to maybe replace some 2016s that will either go into the spare pool or maybe replace Engine 43 and maybe act as Engine 340 and Engine 341 when those units come online in June.
Are the Technical Rescues different from the Rescues right now, or does it come down to the equipment carried?Yeah maybe the city got lazy when writing up that RFP and decided to call the TRs, TRSs, HazMats A/L and HRS all rescues to make things easier for them. I could see new a TRS10 and 11 come out of this RFP since both are long due for a replacement and new TRs since R0118 is the only 2018 rescue with the Technical Rescue configuration.
Code | Response |
01 | Abdominal Pain / Problems |
02 | Allergies / Hives / Medication Reactions |
03 | Animal Bites |
04 | Assault / Rape |
05 | Back Pain |
06 | Breathing Problems |
07 | Burns |
08 | Carbon Monoxide / Inhale / Hazardous Materials |
09 | Cardiac / Respiratory Arrest |
10 | Chest Pain |
11 | Choking |
12 | Convulsions / Seizures |
13 | Diabetic Problems |
14 | Drowning (Near) / Diving Accident |
15 | Electrocution |
16 | Eye Problems |
17 | Falls |
18 | Headache |
19 | Heart Problems |
20 | Heat / Cold Exposure |
21 | Hemorrhage |
22 | Industrial / Machinery Accident |
23 | Overdose / Poisoning / Ingestion |
24 | Pregnancy / Childbirth / Miscarriage |
25 | Psychiatric / Behavioral Problem |
26 | Sick Person (Specific Diagnosis) |
27 | Stabbing / Gunshot Wound |
28 | Stroke / CVA / TIA |
29 | Traffic Injury Accident / MVC |
30 | Traumatic Injuries (Specific) |
31 | Unconscious / Fainting |
32 | Unknown Problem (Person Down) |
33 | Interfacility / Palliative Care |
36 | Pandemic / Epidemic / Outbreak |
50 | Case Entry Protocol (CFD Specific) |
51 | Aircraft Emergency |
52 | Alarm Bells |
53 | Service Call |
54 | Confined Space / Structure Collapse |
55 | Electrical Hazard |
56 | Elevator / Escalator Incident |
57 | Explosion |
58 | Extrication / Entrapment |
59 | Fuel Spill / Fuel Odor |
60 | Gas Leak / Gas Odor (Natural & LP Gases) |
61 | Hazmat |
62 | High Angle Rescue |
63 | Lightning Strike (Investigation) |
64 | Marine / Boat Fire |
65 | Mutual Aid / Assist Outside Agency |
66 | Odor (Strange / Unknown) |
67 | Outside Fire |
68 | Smoke Investigation (Outside) |
69 | Structure Fire |
70 | Train & Rail Collision / Derailment |
71 | Vehicle Fire |
72 | Water / Ice / Mud Rescue |
73 | Watercraft In Distress / Collision |
74 | Suspicious Package / Explosives (Letter, Item, Substance) |
75 | Train / Rail Fire |
76 | Bomb Threat |
77 | Motor Vehicle Collision |
78 | Backcountry Rescue |
79 | Lost Person |
80 | Outside Tank Fire |
81 | Sinking Vehicle / Vehicle In Floodwater |
82 | Vegetation / Wildland / Brush / Grass Fire |
83 | Weather / Disaster Situations |
72 - A | Water Rescue |
61 - B | Building Evacuation & Health / Life Safety |
78 - C | Backcountry Hazards |
77 - D | USAR / Vehicle & Other Hazards |
69 - F | Tunnel Fire |
82 - G | Wildland Fire Hazards |
50 - H | Case Exit Protocol |
Severity | Response |
Alpha | Priority 3 / Cold Response / No IDLH - Unknown / Unconfirmed |
Bravo | Priority 2 / Hot - Cold Response / No IDLH - Unconfirmed |
Charlie | Priority 1 / Hot Response / IDLH - Unconfirmed / Required |
Delta | Priority 1 / Hot Response / IDLH - Unconfirmed / Required |
Echo | Priority 1 / Hot Response / IDLH - Confirmed / Required |
Omega | Priority 3 / Cold Response / No IDLH - No Response Required |
