CFD Apparatus status
ENGINE_4
Are we talking straight stick dry Aerials or straight stick dry Tower ladders?
Also, the bush buggies run a lot of calls and even a lot of training stuff. It would be nice to see more bush buggies in service and spread out the booked down Aerial time but it comes down to cost. The 2 spares are 20 years old and they cover as spares for aquatic units too.. I could see CFD replacing the 2010’s and having 3 spares available. But with the cost of the new Tower’s coming in I don’t think there’s much left in the equipment/life cycle budget right now. But these things change
JABoomer
Originally the Special Events truck was a newer style (trial) mini pumper. It served as Engine 36 back in 2006. CFD was trying out mini-pumper/snuffer (CAFS) units to see if they could replaced bigger Engines. It failed.
CFD then moved the truck to Station 13 and it served as more of a bush buggy out of 13 on the city side for it bit..
Is there a difference between a mini-pumper and a bush buggy?
Does a mini-pumper have some Rescue/Medic equipment that a bush buggy doesn't, or does the bush buggy have more all-terrain features than a mini-pumper?
Curious if there is a difference or if there are more or less interchangeable designations.
ENGINE_4
I think it was actually around 2004 that the mini pumper was in service. I’ll do some research and post it here between CFD bush buggies and the mini pump, but search the first few pages of this forum too. I know there’s info on it in the beginning somewhere.
ENGINE_4
Ok, after much searching I cannot find what I'm looking for, so I am improvising - attached are 2 pictures - 1 of the original "Rapid Response 3" and 1 of the truck in it's older "Bush Buggy" configuration (I believe they are from Jay_911 but I'm not completely sure, so credit to the photographer). Being that the truck is labelled "TR 1700" I assume the rapid response program ran from the year 2000 on until maybe 2001-02? that's a guess, but I don't imagine it lasted long..
This is a link to Hub fire truck's website Salmo — HUB Fire Engines - RR3 was similarly designed to the truck displayed here -notice the pump set-up! I can't find the other pictures I am looking for with regards to the pump set-up and model but it is similar.
Long story short, from what I recall (and if you have more info PLEASE chime in) CFD ran RR3 out of Station 36 (Used to be called Station 3 in Hidden Valley) as then a front line pumper - with 4 ff's. They responded once or twice on a house fire first due and simply didn't have enough pump capacity to knock the fire down let alone put a second line into operation (I don't remember if the pump they had could even run a second hand line) Regardless, a second Engine arrived (along with the rest of the first alarm) more lines were stretched and the fire was knocked down.
The big picture thinking of CFD at the time was maybe they could replace big front-line Engines with these smaller snuffer/mini-pumper style trucks, but they could not. They tried the same things with the Rescues - using a smaller mini-rescue from SVI, same thing. Just couldn't carry all the equipment and get the job done.
Anyways, from there RR3 was turned into a Bush Buggy (second picture) things were changed on the truck and it served all over the city from 8 Station to 13 Station and so on.. eventually the pump and tank were removed or at least the pump was and was replaced for a Rosenbauer UHPS Pump (what's on the current 2010/15 BB's) (That pump and tank are removable keep in mind) from there it served as an Medical Response Unit to today were it is the "Special Events Truck" - likely until its retired.
In theory (at least how I see it) it's essentially a spare Bush Buggy but the pump/tank can be removed (like the 2010/15's) and it can serve as a mini-rescue or whatever else its needed for.
I hope this answers your question JABoomer 😅
ENGINE_4
In CFD terms - the mini-pumper was a mini Engine. I don't think it was designed to go off road to much and had a minimal amount of hose, hand tools, medical equip, etc.. it might have carried a multi tool like CFD Engines do today, but you'll have to ask that question to someone with more knowledge about the Rapid Response program
ENGINE_4
JABoomer, just doing some more research about the rapid response unit - sorry it’s not considered a “mini-pumper” it’s purely a Snuffer truck - CAFS - Compressed Air Foam Systems - Fire247
This is a link to learn a bit more about Snuffer/CAFS pumps and you can get an idea about what kind of pump might have been in the rapid response unit at some point
