Longer than 50 years.
And adequate 95% of the time.
But listening to Radioman911's audio recording from the 4-11 yesterday, you can hear that the command van operator was unable to communicate with the incident commander on several occasions. Digital radios with Vehicle Repeater Systems in the Chief's buggies might have helped. Those might be conventional channels, of course.
But trunked systems also have some advantages.
When you have three or four working fires at the same time (admittedly not often), having them on separate talkgroups with separate dispatchers is preferable.
Even with only one major incident, having the staging area on a separate talkgroup from the operations talkgroup can be useful. In a high-rise fire, the vent group could be on a separate talkgroup.
You don't have rural water supply issues with non-hydranted areas in Chicago, but you do occasionally have "in-line" operations. In that case, a separate talkgroup for water supply units makes sense.
When you have a major storm with wires down all over the area (admittedly not often), putting the reports of wires down and pole numbers on a separate talkgroup from the fires caused by lightning strikes can be an efficient way to operate.
Haz-mat units usually need a separate talkgroup. Bomb techs need a separate TG.
You can't really appreciate the advantages of a trunked system until you've experienced it for awhile.
