Change default "OM" input when "name" field is blank - DM-780
Wrench101
Clearwater, FL
Hi all!
I've been using HRD and DM-780 for a very long time. I recently had a hard drive failure and was forced to reinstall loads of software. One thing that I can't remember for the life of me is how to change the default "OM" name in DM-780 when using macros.
Specifically, when a macro is pulled up that uses "LOG:name" (his:name) but that field is not populated yet in the Add Logbook Entry window, DM 780 will add "OM" as the name instead. I usually change this to "my friend". I've search through the XML files but I guess I haven't found the correct one to modify.
If anyone could point me in the right direction, that'd be awesome.
73
