Change to request a feed change
kendrik578
Live Audio Administrator
Greensboro, NC
To our feed providers: In case you have not noticed, we have change the wording to the request a feed change button in the feed owners page to alleviate some confusion between which button should be used. The button now reads "Request Assistance With Feed". We ask that if you have trouble with your feed or need a change, that you use this method. Some users have been using The "Report A Problem With This Feed" button for their own feed when they have trouble or need help. A reminder that the "Report A Problem With This Feed" button should only be used by listeners reporting a problem to you (the feed provider) regarding an issue with your feed.
This is important as feed issues will get a much faster response when the correct button is used. Thanks.
