I have upgraded the feed configuration for the San Diego City and Poway Fire feed https://www.broadcastify.com/listen/feed/10294
The feed is now running on a program called trunk recorder which uses SDR's instead of a scanner. The computer records the audio and then pushes it up to broadcasify. The advantage to this is that the SDR's are always monitoring the control channel. Plus the SDR's can record several talk groups at the same time and as they end they are pushed up to broadcastify. If all works correctly, this configuration should not miss a single transmission as, at times, several talk groups can be communicating at the same time.
I have also added medics to the feed -- so it is really busy now.
FYI, The SD city and Poway fire feed is the feed that provides audio to Pulsepoint as well as being able to be heard on many of the phone apps.
Any feedback positive or negative would be greatly appreciated either on this forum or in DM.
The feed might go up and down as I make adjustments.
