Changes to SkyWarn info in Tulsa Co, OK
K5TBL
Tulsa, OK
Just noticed that the SkyWarn info is slightly incorrect for Tulsa Co, OK.
146.880 RX 146.280 TX Licensed to WA5LVT Tulsa Repeater Organization.
443.850 RX 448.850 TX Licensed to W5IAS Tulsa Amateur Radio Club.
146.940 RX 146.340 TX Licensed to WA5LVT Tulsa Repeater Organization.
146.835 RX 146.235 TX Licenses to WT5EOC Tulsa Area Emergency Management Authority
146.88 is used by spotters inside Tulsa Co.
443.85 is used by spotters inside the NWS Tulsa CWA, This is the reason for the large link system.
146.94 has become a back up frequency to 146.88
146.835 is a newer repeater put up by TAEMA as a frequency for direct contact with Tulsa EOC
To qualify myself for bringing these corrections, I am the President of Tulsa Amateur Radio Club and a Net Control Officer for the NWS Tulsa SkyWarn.
If anyone needs more info please contact me via email as i do not frequent the forums.
John Carr K5TBL
K5TBL@arrl.net
wa8pyr
Staff member
Lead Database Admin
Ohio
John Carr K5TBL
K5TBL@arrl.net
John,
Please submit the information through the Tulsa County page, and an administrator will work it promptly.
Thanks,
QDP2012
In case you still need it, here is the link (prompts for DB login credentials):
DB Submit: Tulsa County (OK).
Edit: K5TBL, WA8PYR was asking that you submit it to the database's Tulsa County page, not to the Forums' Oklahoma page. The above link is the page where you can submit the info to the database.
Hope this helps,
mikewazowski
Staff member
Forums Manager
Oot and Aboot
John, you need to post your updates to the Database which was linked to above not the Oklahoma forum.
K5TBL
Tulsa, OK
Thank you everyone while I'm new to the forums here I'm not new to forums.
I'll get the info to the link above.
