KT4HX
Can someone tell me how to change a system's type on the fly using the keypad? I had an EDACS system set up in my 396, and found it wasn't tracking properly. I had run into that before and found that the beta ARC396 software had imported a previous EDACS system as "narrow" vice "standard". Once I made the change in that case, it tracked flawlessly. Soooo, since I wasn't at home with the pc, I thought I would just go in via the keypad to check this and change it, if that was the case. However, I could not find any way to do this short of waiting until I got home and making the change via the pc. I scrolled through the Program System menu selections, and referred to the manual but could not find a way to change the system from narrow to standard once the system was in the 396 (only how to do it when doing the initial programming of a system). I must be missing something somewhere. Thanks in advance....Alan
