Thanks for your reply...my problem is that regardless of whether or not I have specific TGID's programmed in, when I enter trunked mode it scrolls through the actual frequencies of the trunked system, not the TGIDs. From the link you posted, this part related to my problem:
"Press the TRUNK button once while scanning your State and you’ll be trunk tracking. In this mode, the scanner will display the TALK GROUP instead of the frequency whenever it stops on a channel that is part of a trunked system. You will be scanning every pre-programmed Trunking system in your area at this point so you can take notes and write down the talk groups that the scanner displays while receiving something of particular interest to you. Pressing the DOWN button while the radio is stopped on a trunked channel will conveniently change the display from the TALK GROUP ID to the FREQUENCY of the channel that you are listening to."
I tried that and it didn't work for me. When I hit the TRUNK button it begins to scan through the frequencies on the trunked system, not the talk groups. Pressing the DOWN button doesn't change the display to or from TALK GROUP ID; instead, it goes to the next channel in the bank, which may or may not have a frequency assigned to it.
The systems I'm trying to join are Moto 800. I tried using the control channels, but it seemed like I could only get the scanner to work if I entered in all the frequencies manually. I must be doing something fundamentally wrong!
