Channel 111
jaymatt1978
Cape May,NJ
I'm getting something down in Cape May, NJ on the n ew 7.5 split frequency of 160.2825 with a PL of 167.9 Comes in during a search so I know it's the correct frequency
u2brent
OAMPT
KRWDPAXKRS1
maybe it's this :unsure:
Freq OutFreq InToneCallsignDescriptionCategoryAgency/CountyState
160.28000 167.9 PLKFM561Hatzolah EMS Dispatch (Simulcast)Hatzolah
Other Fire/EMS
New York CityNY
160.28000 167.9 PLKFM561Hatzolah EMS DispatchFire/EMS
Sullivan County
SullivanNY
ecps92
Taxachusetts
Many times Adj frequencies do bleed over, if you can't find the info by the primary freq, also search +/- based [on your location] on the FCC channel plans, then if nothing and the band is wide open [as of late] keep in mind the Canadian channel plans [especially in our Federal] is not the same
RRR
OFFLINE
USA
Why are they coordinating AAR (Railroad) Frequencies for non-Railroad use?
ecps92
Taxachusetts
Because VHF/UHF is limited and overloading, assigning frequencies from other pools less used is a vital option.
Same reason, the NTIA is allowing some Statewide systems to be assigned Federal VHF/UHF channels.
As GTR mentioned, many a waiver existed long before it became popular to take from other pools.
In Boston we had the same issues 161.2200 for a Local Ambulance Provider as well
