HP-1: Channel Alert HP-1
sfatony
Mesa, AZ
Does anyone know if there is way to be able to listen the different channel alert tones on the HomePatrol-1 Sentinel software program before writing to the HP-1? I have only been able to select a different one each time and then write to HP-1 and do it over with each different tone.
Voyager
When you select the tone, it plays on the speaker.
Just edit a channel and select the alert tone setting, and click on each one.
XTS3000
What I did was program a favorites group for the audio alerts test. Program 9 channels with an unused frequency, and on each of the 9 frequencies, set a different audio alert tone. That way you can step through the 9 channels and hear what each alert tone sounds like.
Voyager
Yes - that is much easier than editing a channel where you can quickly compare tone 9 to tone 4. (yes, that was sarcasm, but I understand why the response was 'necessary')
marksmith
Anne Arundel County, MD
The answer to the original posted question is no.
If you want to hear them as you are setting them you need to set them in the radio directly.
Go to any existing channel and edit. You can go through each of them.
536/996P2/HP1e/HP2e/996XT/
396XT/PSR800/PRO668/PRO652
