grafixman1
Let me state that a couple years ago this scanner was programmed via software so I am a newbie when it comes to programming this.
On the BC346XT, I hit a button in error. Now when a channel is being monitored, the scanner will blank the audio out briefly about every 3 seconds. I checked and priority channel says off. Any ideas would be much appreciated.
The software I located recently is Freescan. It does not recognize the scanner. The Uniden firmware utility did see the scanner so no idea why Freescan can't. I believe I am using an RS-232 to USB adapter cable. Maybe there is a better piece of software available?
