So I'm doing some upgrades to a few vehicles and I'm trying to decide the best wiring configuration. The vehicles currently have a lightbar controller (which appears to draw 30 amps max), and they will soon have an older Kenwood VHF Radio & a XTL 5000. I'd like to avoid any possibility of parasitic drain, so I'm thinking the best option is a ChargeGuard connected directly to the battery, connect the ChargeGuard to a 60 amp relay, connect the relay to a Blue Sea systems fusebox, and connect the fusebox to the three items previously mentioned. Would this be doable?
Also does anyone have suggestions for a 60 amp relay with screw connectors? The relays at my local auto parts store have the standard blades, and the female connector plug wires only use 12 gauge wire. I'm guessing I don't want to connect this directly to a 8 or 6 gauge power wire.
