no8rf
So I plugged my scanner in over 24 hours ago to charge batteries and it still reads charging, per the manual it states the display will changed to CHARGE COMPLETE but this has not happened, is that a misprint in the book ? I removed the batteries and placed them in an external wall charging unit and within 5 mins they showed fully charged, back in the radio and it shows charging.
Also was told the CMOS battery needs to be charged on this scanner, does changing the batteries the normal was take care of this or is there another way ?
Plug the USB cable into the scanner when the scanner is off and "Battery Charge" - "Start Charging? Yes = "E"/ No = "." will display. Press E/yes.
The scanner displays “Normal Charging” and charges the batteries according to the "Set Charge Time" setting.
When charging is finished "Charge Complete" will be displayed
