BC100/BC200: Charging BC200XLT
RMason
Colorado / Mississippi
Found a BC200XLT in a pile of recyclables. Would like to charge it to see if it's worth hanging onto.
Anyone know if there's a compatible after market AC charger out there for it?
From the bc200xlt owner manual:
AC Adaptor
The BC 200XLT can be powered by the AC Adaptor included with the scanner which converts standard household current to 12V DC. Plug the small connector of the AC Adaptor into the jack in the back of the radio marked DC 12V. Plug the other end into any standard 120V AC household outlet. Note: Please be sure to use only model AD-140U AC Adaptor/charger, or the model PS-001 Cigar- ette lighter adaptor (optional), as higher voltage, or reverse polarity may damage your unit.
You should be able to find either the OEM version of the AD-140U charger or equivalent online.
