charging issue
k9jus
clarksville, IN
batteries on the 396xt are dead. When I plug into power supply it reads "charge off" I was thinking there was a setting on this scanner where you could charge the batteries when plugged into a power supply. If anyone knows anything, any feedback would be appreciated.....
wtp
Port Charlotte FL
ok then
slide the back off,
take the batteries out,
flip the little switch to NiMH.
that is the charge setting.
many folks here will tell you the advantage of an external charger, i got a smart one and not one that just charges. sure they cost a bit but, are worth it
k9jus
clarksville, IN
Many thanks to you sir.... Have a great day.... Yes probably will invest in an external charger...73 de k9jus
JamesO
McLean, VA
Yep, MaHa type charger is the best.
You can have spare batteries charging while using the scanner and you would be surprised how the batteries do need condition and sometimes just do not have the mAH they should.
