SquelchKnob
- Joined
- Dec 13, 2007
- Messages
- 528
I have been putting up some scanner audio feeds for Southern MD which can be found here:
http://www.somd.com/scanner/
My scanner feeding Scanner ONE (Charles) is a Uniden BC785D but I do not have the Digital card. At this time I simply have a few conventional freqs programed in that the Fire Dispatch uses for a Simulcast.
I need to try to get to a point where I can trunk track the Charles County System but I want to try to keep the cost down as much as possible. I am hoping I can go out and buy the BCI25D card and that will enable me to pick up the Charles County System.
So my questions are:
Will the BCI25D card paired with the Uniden BC785D scanner let me pick up the Charles County system? I understand there are some different baud rates to factor in when working the APCO-25 Systems and I am unsure if the BCI25D card is the right tool for the job on this prticular system. I am also unsure what baud rate teh system uses.
Does anybody currently living in Charles County use this Scanner/Card combination to monitor the system? I would love to hear your thoughts on it if so.
Thanks for any help you might be able to offer.
