I_am_Alpha1
- Joined
- May 21, 2014
- Messages
- 272
- Reaction score
- 47
DEC are the Talkgroup ID numbers. ARC-500 software from butel.nl along with a cable from E-Bay would be the easiest.how do i program DEC Into my PRO 106?
How would I enter a frequency as a control channel. I can’t seem to find an option anywhere on the scanner (BCD992p2) or the ARC Pro software for that.This is my list as of this morning. DEC is what you are wanting. HEX is for Motorola radios. If there is something in DESCRIPTION it has been confirmed. All 5 digit Talkgroups starting with a "6" are cross patched and are dynamic--thus change until they get everything swapped to the new system. Any of the 12 frequencies can be used as the control channel--enter them all as your control channels.
DEC HEX DESCRIPTION NOTES 1 1 SO Dispatch 1 2 2 SO Dispatch 2 3 3 SO Dispatch 3 4 4 SO Dispatch 4 10 A SO Tac 1 11 B SO Tac 2 12 C SO Tac 3 13 D SO Tac 4 14 E SO Tac channel 20 14 SO Tac channel 21 15 SO Tac channel 24 18 SO Tac channel 25 19 SO Tac channel 201 C9 Jail 202 CA Jail 203 CB Jail 204 CC Jail 301 12D SO Tac channel 302 12E poss so radio heard 303 12F SO Tac channel 304 130 SO Tac channel 1001 3E9 Poss airport 1002 3EA airport ops 1051 41B animal control 1251 4E3 1301 515 Fire Dispatch 1302 516 Fire Dispatch 2 1305 519 Fire Tac 1 1306 51A Fire tac 2 1307 51B Fire tac 3 1308 51C poss fire tac 4 1309 51D poss fire tac 5 1310 51E poss fire tac 6 1315 523 ARFF 1325 52D Fire aining heard 1330 532 heard fire hazmat training 1345 541 EMS to Bayfront Punta Gorda Hospital 1346 542 EMS to Englewood 1347 543 EMS to Fawcett Hospital 1348 544 EMS to Bayfront Port Charlotte Hospital 1361 551 Aeromed 1364 554 1601 641 1666 682 Public Works 1671 6E1 1810 712 1813 715 1851 73B transportation…bus 1901 76D Water Department 2601 A29 PG Police Disp 2602 A2A PG PD Heard 2605 A2D PG PD Heard 2611 A33 PG Police Tac 2801 AF1 PG Fire Disp 1 2805 AF5 PG Fire Tac 1
I have the Homepatrol 1, which only does P25 Phase 1. Now I've updated to the Uniden SDS100, ( Great radio ! ) Now I'm receiving the Phase 2 channels. I was receiving Charlotte county FL Fire, then it disappeared. I did an RR update today, I'm still not receiving Charlotte county Fire dispatch channel. Anyone know why that channel disappeared ?
Okay, interesting. I used discovery mode this morning on the SDS100, found 21 talkgroups - including 1301 and some others not listed on RR. I've added them to the favorites. Works great.Again, THERE IS NO PHASE 2 IN CHARLOTTE COUNTY! None what-so-ever. Everything is Phase 1. Bad info causes people to program radios incorrectly resulting in radios not working. Look at your display, it will show P25 proving you were given bad intel...causing you to purchase a $650 scanner when you possibly didn't need to.
Yes, SDS100/200 are better--I wanted to hate them, but they do work better on this system when I compared to HP1, 996, 436/536, & 396.
Charlotte Fire Dispatch is on TG 1301 and works fine...listening right now. I prefer to create my own favorite scan list versus using the master database. Go to the master database in Sentinel and find Charlotte County. Right click on it and click on append to favorite. Then edit favorite to your personal liking. Go over everything--frequencies and talkgroups to make sure they are correct. Write to radio and select your new list to scan.
Now, the HP1, I'll go back and try to get it working again. I saw this on RR Charlotte County (Project 25) Trunking System, Various, Florida - Scanner Frequencies
Happens to me quite abit one reason I hardly submit them cause someone else don't like it.Others had to get their fingers in there and mess things up.
Thanks, Was wondering why it's not up to date.I have the database admins the correct info...took me a very long time to put it together. Others had to get their fingers in there and mess things up. Check the list I posted above and continue to search could be your best plan.
Using a higher-numbered squelch setting (like 7 or higher) is one thing you can try with your 436, reception wise.I'm a resident of PGI and having the same issues as everyone else with BCD436HP. Nothing so far seems to help. Any suggestions?
I also live in PGI. Have been listening with BCD436HP for number of years. Could not get anything other than garbled transmissions. Bought an SDS100 and that works just fine.I'm a resident of PGI and having the same issues as everyone else with BCD436HP. Nothing so far seems to help. Any suggestions?
Has the old analog system been completely taken out of service?
