Chattanooga Regional P25 System
ButchGone
Ringgold, Georgia
New control channel
The control channel for the Chattanooga simulcast zone of TVRCS has moved to 855.2125 today. During some testing they rolled it back to 856.2375 for a short while, but it's been back to 855.2125. So if you're programming control channels only for a P25 trunking system make sure you have this new control channel plugged in otherwise you won't hear anything. So far, I've logged 855.2125, 856.2375 and 856.7625 as CC's.
BG..
ButchGone
Ringgold, Georgia
That would be the Sharp's Ridge site. How far out from the site did you hear this and what kind of signal strength? Any talk groups? In Chattanooga radio techs have been using TG 1,2,3,4 in the clear. 256 is encrypted. Are you close enough where you might hear the Lenoir City and Madisonville sites?
BG..
tennesseefreq
Seymour, TN
Got talk group 1 with Tech testing around 4PM. My signal was very weak in the building in South Knoxville. I haven't thought to check from the parking lot but I do know I can not get it in Seymour.
INDY72
Indianapolis, IN
Site added.... State didnt go green for some reason.. but the system is updated.
ButchGone
Ringgold, Georgia
N.W. Georgia P25 sites
The FCC database shows license pending approval for the Georgia side of the TVRCS:
Ringgold/LaFayette/Dalton simulcast sites:
851.1750
851.4125 *
851.6875
851.9000 *
852.1625
852.4125 *
852.6000
853.0375
853.4125 *
853.6250
* indicates frequencies currently used at the Ringgold site on the analog/digital system.
The application shows the Ringgold site is authorized to blast out 331 watts, LaFayette 162 watts and Dalton 177 watts.
Canyon Ridge-Lookout Mountain site, Dade County:
851.2125
851.3375
852.0375
853.1625
Application shows the Dade County site authorized for up to 177 watts.
BG..
INDY72
Indianapolis, IN
331 Watts... WOW thats some serious firepower for P-25......Should give massive coverage. Hows the terrain there?
ccfire
tellico plains, TN
Hey guys just read about the monroe county madisonville site I cannot listen to 700 MHZ with my pro 2096. PS hoping to buy a new scanner in the near future any way has any onr heard if its up and running or if they just got the go ahead from the fcc and have not purchased or installed any epuipment yet.
richard4537312
Cleveland, TN
Actually you can listen to these 700 Mhz frequencies with your Pro 2096. Using Win96, activate extended freqencies. I've been monitoring them on my Pro96. You will have to monitor conventionally. At least for now, it won't trunk track on these frequencies. Simply load all of the 700 Mhz frequencies for the site you want to monitor, turn off the delay for each channel, lock out the control channel(s), and it should work just fine.
hcpholder
851.1750
851.4125 *
851.6875
851.9000 *
852.1625
852.4125 *
852.6000
853.0375
853.4125 *
853.6250
851.2125
851.3375
852.0375
853.1625
BG..
Don't mean to sound dumb or something, so I I now place these in a scanlist as P25 system?
INDY72
Indianapolis, IN
Yes you program in as P-25 once the site is fully upgraded. Until then you leave it as is.., and as for the 96/2096... you can monitor in conventional scan mode, you can not trunk track a fully 700 MHz system. Now on mixed sites, if the CC's are 800 MHZ, then your good to go and can trunktrack fine.
W4EMS
NoVA
Did I understand correctly that on systems with 800 Mhz cc's that use 700 MHz voice channels the Pro-96 will trunk these?
INDY72
Indianapolis, IN
Yes if the CC's are 800 mhz the 96/2096 can follow the traffic. See the AWIN, and LWIN for examples. The NOLA sites ofthe LWIN has one site that can be monitored by the scanners, as well as the one AWIN site... Its the set up using the 700 MHz CC's that can't be tracked. For those sites, you have to do it the old fashioned pre-trunking days. At least it WILL follow the digital LOL.
ButchGone
Ringgold, Georgia
New Bradley County site
License pending now for another 700MHz site for the TVRCS, to be located along I-75 near Charleston in northern Bradley County:
Callsign WQKQ451
769.60625
770.53125
772.38125
772.73125
773.45625
BG..
hcpholder
Tennessee Valley Regional Communications System
2-001 2-1 Chattanooga City Simulcast
855.21250a 856.23750c 856.76250a 857.23750 857.43750 857.48750 857.71250 857.93750
858.23750 858.43750
The SY:2A5 R002 S001
Currently the frequency 856.76250a is showing as "S010" instead of the original "S001". Is there any reason for this, or has my Pro-106 gone wacky? Thanks.
INDY72
Indianapolis, IN
During implementation,there may be several changes to the ID's etc until the system is multi site wide area trunking. The LWIN and MSWIN both have recently undergone changes to CC's, and site ID's etc due to changes. Remember this system is truly a newborn still adding sites, and undergoing testing.
ButchGone
Ringgold, Georgia
New talkgroup?
15012 is active today on the Chattanooga TVRCS system. Sounds like building maintenance at some government facility. Maybe these are the first users to "test" system? The audio is very good!
The Lookout and Signal sites are either not active or very low power, as it seems the system is firing from the White Oak and Collegedale sites only.
BG..
ButchGone
Ringgold, Georgia
First TVRCS users?
Talkgroup 15001 is active today with traffic that sounds like a jail or detention center. It's not Hamilton County's jail since they're still on 21200 on the analog system. 15012 was heard yesterday with maintenance crews that talked about jail related issues like the "sallyport." And there was some unknown stuff on 15008.
Also, it appears the Lookout Mnt. and/or the Signal Mnt. sites are back up today.
Anybody know where this jail/detention center is? Catoosa County bought 18 new 800MHz digi capable radios recently according to a news article so could this be them?
I see a new system ID as 02A5h-0210 for the Chattanooga simulcast cell.
BG..
