Ecfsar18
I recently had a spare Wilson 2000 CB antenna and made use of it by taking just the bottom 10 inch shaft with 3/8 threads and using a 3/8 magmount works good for mobile or portable use for uhf milair-is more broadbanded than a standard say 102 whip cut down because the diameter is at least twice as thick i'd say..... If have one of these give it a whirl or use as a spare etc........ Note can order the lower shaft itself I believe still from Wilson antenna... Also note I believe there is an 18 inch shaft one also which would prob work great as a vhf marine or like a railband antenna,WX or MURS!
