Cheapest way I can Keyload an XG100P with KFD tool without KFD100 since it's unobtainable?
Mogley
I purchased an XG-100p and KFDtool seems great except that KFD100 usb device thing has been sold out for years (I've read). What's the easiest way and cheapest way I can load keys onto it without spending a grand on a KVl 3000?
I've read about a KFD shield but have zero idea how I would even set one up.
Any recommendations?
Thanks in advance.
Mogley
Ok so if I get this, (Sorry for the dumb question)
I get a 3.5 to hirose adapter, grab hirose connector to harris adapter online, then connect other side to USB and then my computer? Thats it?
prcguy
Yes. I have an early version of the micro and it works the same as my original KFD100. It just uses a different KFDtool program to run it.
Or as mentioned the Harris key admin works fine after you have looked some more and if you have a factory programming cable. But the KFD stuff is much easier to deal with and you can copy, past, email keys if needed where anything legit like Harris key admin or Motorola KVL is locked down but as it should be.
nikronzo
Harris KeyAdmin is licensed and you would need to purchased a license key. The KeyAdmin can load keys but you need Encryption to be enabled on the radio and have the programming cable.
The KFDtool needs a keyloading adapter to connect to it. Cheapest on the market right now is this: L3 Harris Keyloading Adapter for Unity XG-100P and XL-200/185P Portable Radios | eBay
All the KFDtool software instructions are online in github GitHub - KFDtool/KFDtool: Open Source P25 KFD (Key Fill Device/Keyloader/KVL)
prcguy
This is probably the cheapest Hirose to XG-100P adapter. I bought a $39 Hirose audio adapter then moved the pins around and put in a programming resistor, or maybe it was a diode, I forget. Perfect keylading adapter. Just look for a cheap audio adapter that has all the pin holes so you can move pins around and the pinout is somewhere online.
Radio99
NW Chicago Suburbs
I recently serviced a XG-100P which I successfully loaded encryption keys to using an OEM cable and a Motorola KVL 3000+. No issues.
I cannot, however, get the corresponding XG-75M to accept encryption keys using the appropriate OEM cable and the KVL. Any ideas on what I am missing here? Thanks in advance.
K2NEC
NA
What algos and what cable? If it's the front mic port, that cable only works on the XG100m
prcguy
I have a 75M loaned out to a friend and kind of remember using Harris keyadmin and the DB9 programming cable for AES.
tweiss3
Is it time for Coffee?
Ohio
I thought I remember reading the XG75 radios were KeyAdmin only, but I could be thinking of the P7100's.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Look at the KFD micro. Cheap, available and they work fine on the XG-100P.
This is the answer.
IF you are not super concerned with key variable security.
It is NOT as secure as a KVL or the Harris Key Manager.
Use a disk encryption program, and encrypt the key container.
I have a KFD Mico, and it's super simple to use. It's inexpensive and just works.
