JP_in_Atl
Over the past 2 weeks or so the signal I am getting on my Pro-91 has been getting blasted by another transmission that seems to be sort of scrambled. Every now and then it comes through clearly, and you can make someone out saying "Thank you" or a unit number... But it's blasting right over the "normal" freqs that are used by Fire/PD out here... so between normal Woodstock/Canton/Cherokee transmissions, when you'd get static, you get this garbled mess, that has a 2 tone end whenever someone keys off...
It's danged annoying...
Part II: This is a general question... on the online feeds for various counties/cities... what are the "powers that be" using for static suppression between transmissions? Noise cancellation or some such? I'm curious as to how that's done.
Thanks for the indulgence and information.
JP
JP
