Chesapeake Fire/EMS Unit Designation Question
gosharks
I have just started listening to Chesapeake Fire/EMS after several years away, and I've noticed that on some EMS calls a unit called "Am" or "A.M." is dispatched rather than a Medic. Is this a BLS Ambulance vs. a "Medic" being ALS?
If so, do ALS/BLS ambulances rotate through the stations or are they assigned permanent locations based on call volume? Is this due to budget cuts?
pduffy211
Yorktown VA
Call Signs
Although I'm not monitoring Chesapeake I believe it is along the same lines as The County. You have the normal EMS unit which is a standard response ambulance and then you have a ALS response unit which may be a pickup with a specially qualified Advanced EMT. You will usually hear these respond with or shortly after the ambulance for situations like code blue or fall from over 6 feet. Something that requires truely advanced life support. These guys take turns and cover more than one district responding to the advanced cases. I think it was a cost saving change as keeping all the advanced certifications is rather expensive and time consuming.
mikext
Chesapeake Fire/EMS
Amb's are Emt-Enhanced staffed transport units
Medic's are ALS Emt-P or Emt-I transport Units
ALS 4 and 10 ALS quick response units
EMS 1,2 & 3 Supervisors
NET Care 1 and 2 are part time EMT staffed non-emergency tranport units.
gosharks
Does anyone work for Chesapeake and can answer some questions for me?
What is Amb 11's schedule for being in-service? How about Amb 6?
Are Engine 24 and Engine 28 in-service full-time and do they split the district with Engine 4 and Engine 8? How are they assigned calls?
rescue674aa
I’m an idiot
Chesapeake
Amb 11 is 0700 - 1900. Amb 6 is only occasional. 24 and 28 go out of service if a lot of people are off
