Chesapeake Rebanded last night new info in the database, will add more frequencies as trunker displays them
Mike
Mike
Mike
After reprogramming my PSR-500 and PRO-96 scanners, Chesapeake would not track correctly until I applied the custom trunking tables for a 800 Mhz rebanded system. This system may not be able to be followed correctly on the older scanners that do not support custom trunking tables.
Yes that looks to be true. Some of the frequencies have a 0 in the fourth decimal position which would put it on a channel number scanners would not recognize.After reprogramming my PSR-500 and PRO-96 scanners, Chesapeake would not track correctly until I applied the custom trunking tables for a 800 Mhz rebanded system. This system may not be able to be followed correctly on the older scanners that do not support custom trunking tables.
It doesn't sound like it. I programmed my pro-197 from RR also, and mine matches yours (at least what you provied above). I did have to do mine twice.I have just updated my RS Pro 197
Deleted Chesapeake and re-entered it via Win500 and RR
Still nothing
Win500 has the following:
Type - MOT 800/900
Trunking Tables - Custom
CC - 4 as listed in RR
Am I missing anything?
