Chester County Emergency Services Trunked "License"
Porch
I'm new to scanning and was wondering if anyone could explain whether the frequency/license below for Chester County 800 mHz conventional is really "Conventional" or actually "trunked" (or to be trunked at some future time)?
The entry:
Chester County 800 MHz Conventional
Frequency Input License Type Tone CH Description Mode
856.23750 811.23750 WPHC705 RM Licensed FM
When you click the callsign link ( http://www.radioreference.com/modules.php?name=RR&action=fcc&cs=WPHC705 ) to the license information it says something about the system being trunked? What gives? Is it conventional or trunked. Is this a database glitch? Please explain enlightened ones!
Porch
ajftgov
Chesco trunked system
Yes it is a trunked system but one that is not capable of being scanned in the trunked mode (i.e. no scanner will follow a conversation, aka talk group id). You can listen to all the voice channels and most times the activity level is low enough you can catch the brunt of the conversaton. You can use virtually any 800Mz scanner. This is not a digital system. The fire board transmissions are broadcast on VHF and on the 800MHz system. The principal channel I hear in SE Chester County is 159.600.
ctrabs74
California, PA
Porch said:
The entry:
It's an LTR Multi-Net system, which can be monitored in conventional mode by inputting the freqs listed in this database:
http://www.radioreference.com/modules.php?name=RR&sid=987
LTR Multi-Net can not be programmed as a trunked system in any scanner on the market presently. 856.2375 is LCN #12 (or the 12th freq to program out of the 16 listed).
