1150016 is West Fire Console
1150017 is Central Fire Console
1150018 is East Fire Console
Thanks for the update..
All of the portables (FD and PD) were issued with just the portable number programmed. Each department was charged with assigning the radios and completing a spread sheet where an alias was assigned to each radio. Apparently some of them have not done it yet. For example - what you should be seeing on the fire end are designations like: CHF xx (Chief from Station xx); SQD xx (Squad Unit from Station xx); and on down the apparatus/officers numbering system per the Chester County Fire Chief's Association.
Correct me if I'm wrong, but you'll only see the aforementioned designations if you have that spreadsheet and program them into your radio, otherwise you'll just see the RID. It won't happen without some intervention of the user.
Bit off topic but am seeing a new addition to Penn State Police flying
around doing circles today on my mode s box around Lancaster/Chester County areas.
(AC1967) N879ST PC12 Pilatus PC-12/47E 1930z
FAA Registry - Aircraft - N-Number Inquiry
Maybe testing it out.. This is cool plane type.. Had PC-12 last year buzz my house inbound
Cecil airport and sounds like P-51 Mustang on steroids.. Rumbles with high super charged single engine horsepower.
Good for transporting pax at high altitudes and speed.. USAF had mess of them but sold off most
as they guzzle fuel for single engine plane but no surprise with all that horsepower.
USAF stuck with their Beech BE20/C12 types..
Does anyone know where I can get a Homepatrol -1 programmed for the new Chester County System? Or, will it work? I downloaded the new DB and it has been silent. Listening to the live feed, there should be plenty of activity. I thought I understood this stuff, clearly the new system proved me wrong.
Thanks pwscott. Sounds like a pretty big investment, but a very nice scanner. Are you able to pick up most traffic on the new system? Also, are you able to isolate the talkgroups so that you don't hear everyone in the county?
Thanks for the help.
Correct. The county will change a radio ID of "211500" to "CHF21P" if that's what they send in, but the radio itself will still be throwing out an ID of 211500, and that's what you will see on a scanner.
Thanks for the advice. The BCD436HP is perfect. Picking up all the Chester County P25 trx very strong. Easy programming with Sentinal. Does anyone know how I can keep Sentinal from restoring all of my scanner settings back to default each time I write back to the scanner? (Display, Key Beep, Quick Keys....etc)Both the BCD436HP and the HP-2 seem to track and receive the system extremely well. I don't think I'm missing anything and am seeing UIDs of radios etc. I'm in a very good, high elevation location and using just the stock rubber ducky antennas on each.
