Chester Palmetto 800
Bonkk083
Union, SC
What is the Id for fire and ems I put what was in the database but it pickup police with fire and ems like a roam
Whiskey3JMC
DXpeditioner, RRDB & Google-fu ninja 4 hire
Philly burbs 🇺🇸
I'm sure it would help the group if you were more specific about what TGID(s) you put in. One dispatch & numerous tac channels listed for Fire/EMS...
Chester County
DECHEXModeAlpha TagDescriptionTag
42001a411DChester SD DispSheriff Ch 801 DispatchLaw Dispatch
42002a412DChester SD 802Sheriff Ch 802Law Tac
42003a413DEChester SD 803Sheriff Ch 803Law Tac
42004a414DEChester SD 804Sheriff Ch 804Law Tac
42005a415DChester SD 805Sheriff Ch 805Law Tac
42026a42aDFrt Lawn PD TalkFort Lawn PD Talk-aroundLaw Tac
42027a42bDFrt Lawn PD RoamFort Lawn PD RoamLaw Tac
42054a446DChst FD/EMS DisFire/EMS DispatchMulti-Dispatch
42056a448DChst FD/EMS Ops1Fire/EMS Ops 1Multi-Tac
42057a449DChst FD/EMS Ops2Fire/EMS Ops 2Multi-Tac
42058a44aDChst FD/EMS Ops3Fire/EMS Ops 3Multi-Tac
42059a44bDChst FD/EMS Ops4Fire/EMS Ops 4Multi-Tac
42060a44cDChst FD/EMS Ops5Fire/EMS Ops 5Multi-Tac
42115a483DChesterCo EMEmergency ManagmentEmergency Ops
42116a484DChesterCo EM RmEmergency Management RoamEmergency Ops
42351a56fDChester PD DispChester PD Ch 1 DispatchLaw Dispatch
42352a570DEChester PD NarcChester PD Ch 2 Gang Unit NarcoticsLaw Tac
42353a571DChester PD RoamChester PD Ch 3 RoamLaw Tac
42381a58dDGrtFalls PD DispGreat Falls PD DispatchLaw Dispatch
42382a58eDGrtFalls PD RoamGreat Falls PD RoamLaw Tac
42411a5abDeGreat Falls PDGreat Falls PDLaw Tac
Bonkk083
Union, SC
Chester County
I put in the 42054 is that the right one to use
brian
DB Administrator
South Carolina
Yes, if we assume that Chester Fire and EMS are actively using Palmetto 800. They may still be active on VHF. Chester County EMS also has a talkgroup on Fleettalk that I think they used at some point. There probably needs to be some updated confirmation on exactly which radio system each agency is using.
Sometimes, talkgroups on a radio system are assigned with the intent that they can be used, or will be used at some point or in certain circumstances. It doesn't necessarily mean they are actively used.
drew7262
Chester County Fire And EMS are now using the palmetto 800 full time as of late last summer, from what I have heard and they are using APX 4500 mobiles and 4000 portables. Fire and EMS are now dispatched jointly on the same TG and VHF is used for backup communications.
Bonkk083
Union, SC
The 42052 is the right id
drew7262
42054 and I would add all of the ops channels into my scan list as well. I prefer id search while scanning but if you don’t want to hear everything coming off the site then ID SCAN. Just out of curiosity what scanner are you using?
Bonkk083
Union, SC
Uniden 996p2 and 536
drew7262
It shows as simulcast up there, I have a family member that scans the simulcast on their 996p2 with no issues in multiple locations. Good Luck!
