Chevron Richmond Refinery smartnet gone awfully quiet in last few days
rstrose
Oaktown
There was chatter on the fire channel a couple of weeks ago comparing performance of "new digital radios" vs old analog radios. Have not heard a word in a few days which is highly unusual. Existing system seems up. Maybe they went encrypted and the radioshack pro197 or 106 cannot track or decode.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Check FCC for new licenses, and if not run a control channel decoding program to see what is actually happening on the system. Then start looking for a new digital system if there is no activity. If they are on 800/900Mhz, they may have gone P25 or DMR or NXDN. In the process, they may be changing over a channel at a time, untill the new system is built out.
Sent from my iPad using Tapatalk
rstrose
Oaktown
Upon further investigation as I dial thru the trunked channels other than the control channels on my old 996t it sounds like heavy encryption on the existing rebanded Motorola Type II smartnet. sounds very much like the DES encrypted radio of San Francisco Hospital ringdown traffic.
kayn1n32008
Sector 001
Running something like unitrunker will tell you if the channels are encrypted.
Chevron Richmond just completed the installation of a new Motorola P25 Phase II system.
Their old Smartnet system is over.
They expanded the emissions types on their existing frequencies to include P25.
The subscribers are Motorola APX series radios with AES 256 encryption options installed.
Discussions with folks indicate they will likely run the entire system encrypted -- but I have not seen this on paper yet.
Most subscribers are APX 6000 Li -- with CFD using APX 7000 / 75000. These subscribers were deployed about a year ago. The 6000 Li is only capable of holding ONE trunking system at a time. Therefore, a cutover period is necessary. CFD have likely moved over to the new system, while operations, maintenance and turnaround radios are benched for reprogramming.
One could simply check the 10 existing frequencies for the presence of a P25 control channel... it'll be there.
Here's your new Chevron Richmond system. After a conversation, it is all but certain they will run 100% encrypted on all talk groups.
Someone may as well create a submission for the new system with a note that it's 100% encrypted and deprecate the old system. It's over.
Code:
FileVersion:8
-TowerInfo
#This section is here for information only.  With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
[B]System ID             : 5E8[/B]
System Name           :
WACN                  : BEE00
Tower Number (Decimal): 1-1
Tower Number (Hex)    : T0101
Tower Description     :
Control Capabilities  : Data,Voice,Registration
Flavor                : Phase 2
Call Sign(s)          :
Timestamp             : Mon Apr  6 14:01:39 2015
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,935.01250,0.01250,-39.00000,"Confirmed",0.01250,1
05,935.01250,0.01250,-39.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0749","d",855.68750,"00-0749",810.68750,0,0
"00-0853","d",856.33750,"00-0853",811.33750,1,0
"00-1009","d",857.31250,"00-1009",812.31250,1,0
"00-1013","ad",857.33750,"00-1013",812.33750,0,0
"00-1173","a",858.33750,"00-1173",813.33750,0,0
"00-1333","a",859.33750,"00-1333",814.33750,0,0
"00-1493","c",860.33750,"00-1493",815.33750,0,0
"02-0748","v",855.68750/0,"02-0748",810.68750/0,1,15
"02-0749","v",855.68750/1,"02-0749",810.68750/1,1,14
"02-0852","v",856.33750/0,"02-0852",811.33750/0,0,19
"02-0853","v",856.33750/1,"02-0853",811.33750/1,1,16
"02-1008","v",857.31250/0,"02-1008",812.31250/0,1,15
"02-1009","v",857.31250/1,"02-1009",812.31250/1,0,18
"02-1012","v",857.33750/0,"02-1012",812.33750/0,0,1
"02-1013","v",857.33750/1,"02-1013",812.33750/1,0,2
Here is a log I ran for a few minutes. I didn't have much time, but I saw about 25-30 talk groups, all encrypted.
Code:
Type	Channel	Frequency	TG ID	TalkGroup Description	Radio ID	Radio Description
Group (Enc)	02-1009	857.31250/1	605	T: 101 DT: 4/6/15@13:56	1021	TG: 605 DT: 4/6/15@13:56
Data	00-0749	855.6875			1907
Data	00-0749	855.6875			1453	TG: 0 DT: 4/6/15@13:55
Group (Enc)	02-0853	856.33750/1	1009	T: 101 DT: 4/6/15@13:51	2010	TG: 1009 DT: 4/6/15@13:55
Group (Enc)	02-0852	856.33750/0	1415	T: 101 DT: 4/6/15@13:51	2846	TG: 1415 DT: 4/6/15@13:56
Group (Enc)	02-1008	857.31250/0	1005	T: 101 DT: 4/6/15@13:56	1615	TG: 1005 DT: 4/6/15@13:56
Data	00-1013	857.3375			1353	TG: 0 DT: 4/6/15@13:55
Group (Enc)	02-1009	857.31250/1	603	T: 101 DT: 4/6/15@13:54	900
Data	00-0749	855.6875			62
Data	00-0749	855.6875			62	TG: 0 DT: 4/6/15@13:56
Group (Enc)	02-0852	856.33750/0	1415	T: 101 DT: 4/6/15@13:51	2836	TG: 1415 DT: 4/6/15@13:56
Data	00-0749	855.6875			2104	TG: 0 DT: 4/6/15@13:56
Group (Enc)	02-1008	857.31250/0	603	T: 101 DT: 4/6/15@13:54	900	TG: 603 DT: 4/6/15@13:56
Group (Enc)	02-1009	857.31250/1	1005	T: 101 DT: 4/6/15@13:56	1549	TG: 1005 DT: 4/6/15@13:56
Group (Enc)	02-1008	857.31250/0	603	T: 101 DT: 4/6/15@13:54	903	TG: 603 DT: 4/6/15@13:56
Group (Enc)	02-0853	856.33750/1	1415	T: 101 DT: 4/6/15@13:51	2832	TG: 1415 DT: 4/6/15@13:56
Data	00-0749	855.6875			2538	TG: 0 DT: 4/6/15@13:56
Group (Enc)	02-0853	856.33750/1	1415	T: 101 DT: 4/6/15@13:51	2846	TG: 1415 DT: 4/6/15@13:56
Data	00-0749	855.6875			1907	TG: 0 DT: 4/6/15@13:56
Group (Enc)	02-0852	856.33750/0	1005	T: 101 DT: 4/6/15@13:56	1615	TG: 1005 DT: 4/6/15@13:56
Group (Enc)	02-1009	857.31250/1	1009	T: 101 DT: 4/6/15@13:51	2010	TG: 1009 DT: 4/6/15@13:55
Group (Enc)	02-1013	857.33750/1	403	T: 101 DT: 4/6/15@13:54	858	TG: 403 DT: 4/6/15@13:56
Group (Enc)	02-0852	856.33750/0	1005	T: 101 DT: 4/6/15@13:56	1549	TG: 1005 DT: 4/6/15@13:56
Data	00-0749	855.6875			2278	TG: 0 DT: 4/6/15@13:56
Data	00-0749	855.6875			336	TG: 0 DT: 4/6/15@13:56
Data	00-0853	856.3375			1907	TG: 0 DT: 4/6/15@13:56
Data	00-0853	856.3375			1453	TG: 0 DT: 4/6/15@13:55
Data	00-0853	856.3375			2020	TG: 0 DT: 4/6/15@13:57
Group (Enc)	02-1009	857.31250/1	1009	T: 101 DT: 4/6/15@13:51	2011	TG: 1009 DT: 4/6/15@13:54
Data	00-0853	856.3375			2278	TG: 0 DT: 4/6/15@13:56
Group (Enc)	02-1008	857.31250/0	605	T: 101 DT: 4/6/15@13:56	1021	TG: 605 DT: 4/6/15@13:56
Data	00-0853	856.3375			713	TG: 0 DT: 4/6/15@13:57
Group (Enc)	02-0749	855.68750/1	605	T: 101 DT: 4/6/15@13:56	1022	TG: 605 DT: 4/6/15@13:57
Data	00-0853	856.3375			2104	TG: 0 DT: 4/6/15@13:56
Group (Enc)	02-0749	855.68750/1	605	T: 101 DT: 4/6/15@13:56	1021	TG: 605 DT: 4/6/15@13:56
Data	00-0853	856.3375			2033	TG: 1403 DT: 4/6/15@13:57
Group (Enc)	02-1009	857.31250/1	1419	T: 101 DT: 4/6/15@13:57	1941	TG: 0 DT: 4/6/15@13:51
Data	00-0853	856.3375			332	TG: 0 DT: 4/6/15@13:57
Data	00-0853	856.3375			1920	TG: 0 DT: 4/6/15@13:57
Group (Enc)	02-0749	855.68750/1	1419	T: 101 DT: 4/6/15@13:57	1943	TG: 0 DT: 4/6/15@13:54
Data	00-1009	857.3125			336	TG: 0 DT: 4/6/15@13:56
Data	00-1009	857.3125			2278	TG: 0 DT: 4/6/15@13:56
Group (Enc)	02-0748	855.68750/0	1419	T: 101 DT: 4/6/15@13:57	1952
Data	00-1009	857.3125			332	TG: 0 DT: 4/6/15@13:57
Data	00-1009	857.3125			1914	TG: 405 DT: 4/6/15@13:55
Data	00-1009	857.3125			1920	TG: 0 DT: 4/6/15@13:57
Data	00-0853	856.3375			1908	TG: 0 DT: 4/6/15@13:58
Group (Enc)	02-0749	855.68750/1	1613	T: 101 DT: 4/6/15@13:53	2754
Group (Enc)	02-1008	857.31250/0	1419	T: 101 DT: 4/6/15@13:57	1941	TG: 0 DT: 4/6/15@13:51
Group (Enc)	02-1009	857.31250/1	405	T: 101 DT: 4/6/15@13:55	2358	TG: 405 DT: 4/6/15@13:59
Data	00-0749	855.6875			332	TG: 0 DT: 4/6/15@13:57
Group (Enc)	02-1008	857.31250/0	1419	T: 101 DT: 4/6/15@13:57	1943	TG: 0 DT: 4/6/15@13:54
Data	00-0749	855.6875			713	TG: 0 DT: 4/6/15@13:57
Data	00-0749	855.6875			1914	TG: 405 DT: 4/6/15@13:55
Data	00-0749	855.6875			1920	TG: 0 DT: 4/6/15@13:57
Group (Enc)	02-0852	856.33750/0	1419	T: 101 DT: 4/6/15@13:57	1943	TG: 0 DT: 4/6/15@13:54
Data	00-1009	857.3125			810
Data	00-1009	857.3125			1908	TG: 0 DT: 4/6/15@13:58
Group (Enc)	02-0749	855.68750/1	1419	T: 101 DT: 4/6/15@13:57	1941	TG: 0 DT: 4/6/15@13:51
Group (Enc)	02-1008	857.31250/0	1409	T: 101 DT: 4/6/15@13:51	2187	TG: 1409 DT: 4/6/15@14:00
Group (Enc)	02-0748	855.68750/0	603	T: 101 DT: 4/6/15@13:54	906	TG: 603 DT: 4/6/15@13:54
Group (Enc)	02-0748	855.68750/0	805	T: 101 DT: 4/6/15@14:00	2406	TG: 805 DT: 4/6/15@14:00
Group (Enc)	02-0749	855.68750/1	603	T: 101 DT: 4/6/15@13:54	906	TG: 603 DT: 4/6/15@13:54
Group (Enc)	02-1008	857.31250/0	1409	T: 101 DT: 4/6/15@13:51	3051	TG: 1409 DT: 4/6/15@14:00
Data	00-0749	855.6875			2089	TG: 0 DT: 4/6/15@14:01
Group (Enc)	02-0852	856.33750/0	1409	T: 101 DT: 4/6/15@13:51	2176	TG: 1409 DT: 4/6/15@14:01
Group (Enc)	02-1009	857.31250/1	609	T: 101 DT: 4/6/15@14:01	2766
Group (Enc)	02-0853	856.33750/1	805	T: 101 DT: 4/6/15@14:00	1301	TG: 805 DT: 4/6/15@14:01
Group (Enc)	02-0852	856.33750/0	1413	T: 101 DT: 4/6/15@13:51	2786	TG: 1413 DT: 4/6/15@13:51
Group (Enc)	02-0853	856.33750/1	805	T: 101 DT: 4/6/15@14:00	2406	TG: 805 DT: 4/6/15@14:00
Data	00-1009	857.3125			2765	TG: 0 DT: 4/6/15@14:01
Data	00-1009	857.3125			2101	TG: 0 DT: 4/6/15@14:01
Data	00-1009	857.3125			1354	TG: 0 DT: 4/6/15@14:01
Group (Enc)	02-0852	856.33750/0	1007	T: 101 DT: 4/6/15@14:01	1701
Group (Enc)	02-0852	856.33750/0	1007	T: 101 DT: 4/6/15@14:01	1715	TG: 1007 DT: 4/6/15@14:01
Data	00-1009	857.3125			76	TG: 0 DT: 4/6/15@14:01
Group (Enc)	02-0852	856.33750/0	1007	T: 101 DT: 4/6/15@14:01	1701	TG: 1007 DT: 4/6/15@14:01
Group (Enc)	02-0853	856.33750/1	1403	T: 101 DT: 4/6/15@13:53	2050	TG: 1403 DT: 4/6/15@14:01
Group (Enc)	02-0749	855.68750/1	403	T: 101 DT: 4/6/15@13:54	653	TG: 403 DT: 4/6/15@14:01
Group (Enc)	02-0748	855.68750/0	1005	T: 101 DT: 4/6/15@13:56	1615	TG: 1005 DT: 4/6/15@13:56
Group (Enc)	02-0749	855.68750/1	403	T: 101 DT: 4/6/15@13:54	620
Group (Enc)	02-0853	856.33750/1	1403	T: 101 DT: 4/6/15@13:53	2039	TG: 1403 DT: 4/6/15@14:01
Group (Enc)	02-0852	856.33750/0	403	T: 101 DT: 4/6/15@13:54	653	TG: 403 DT: 4/6/15@14:01
Group (Enc)	02-0748	855.68750/0	1005	T: 101 DT: 4/6/15@13:56	1549	TG: 1005 DT: 4/6/15@13:56
Group (Enc)	02-0853	856.33750/1	1005	T: 101 DT: 4/6/15@13:56	1615	TG: 1005 DT: 4/6/15@13:56
Group (Enc)	02-0852	856.33750/0	403	T: 101 DT: 4/6/15@13:54	620	TG: 403 DT: 4/6/15@14:01
Group (Enc)	02-0749	855.68750/1	3	T: 101 DT: 4/6/15@13:53	1701	TG: 1007 DT: 4/6/15@14:01
Group (Enc)	02-0852	856.33750/0	609	T: 101 DT: 4/6/15@14:01	2766	TG: 609 DT: 4/6/15@14:01
Group (Enc)	02-0748	855.68750/0	403	T: 101 DT: 4/6/15@13:54	653	TG: 403 DT: 4/6/15@14:01
Data	00-1009	857.3125			2029	TG: 3 DT: 4/6/15@14:01
Group (Enc)	02-0852	856.33750/0	403	T: 101 DT: 4/6/15@13:54	623	TG: 403 DT: 4/6/15@14:02
Data	00-0749	855.6875			2029	TG: 3 DT: 4/6/15@14:01
Group (Enc)	02-1008	857.31250/0	1005	T: 101 DT: 4/6/15@13:56	1549	TG: 1005 DT: 4/6/15@13:56
Data	00-0749	855.6875			1354	TG: 0 DT: 4/6/15@14:01
Talk groups logged:
Code:
FileVersion:6
# Talkgroup List for this system
# Format:  Talkgroup,Priority,Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),FirstSeen(Unix),FirstSeen(Human),FG Color,BG Color,EncSeen,Hits
# Priority Values:  0=Ignore, 1=Highest priority, 99= Lowest Priority
3,50,"T: 101 DT: 4/6/15@13:53",1428353595,"04/06/2015 @ 13:53",1428353595,"04/06/2015 @ 13:53","#000000","#000000","N",0
5,50,"T: 101 DT: 4/6/15@13:59",1428353941,"04/06/2015 @ 13:59",1428353941,"04/06/2015 @ 13:59","#000000","#000000","N",0
19,50,"T: 101 DT: 4/6/15@13:53",1428353661,"04/06/2015 @ 13:54",1428353637,"04/06/2015 @ 13:53","#000000","#000000","Y",2
205,50,"T: 101 DT: 4/6/15@13:59",1428353958,"04/06/2015 @ 13:59",1428353958,"04/06/2015 @ 13:59","#000000","#000000","N",1
225,50,"T: 101 DT: 4/6/15@13:52",1428353543,"04/06/2015 @ 13:52",1428353543,"04/06/2015 @ 13:52","#000000","#000000","N",0
403,50,"T: 101 DT: 4/6/15@13:54",1428353809,"04/06/2015 @ 13:56",1428353659,"04/06/2015 @ 13:54","#000000","#000000","Y",4
405,50,"T: 101 DT: 4/6/15@13:55",1428353948,"04/06/2015 @ 13:59",1428353730,"04/06/2015 @ 13:55","#000000","#000000","Y",1
407,50,"T: 101 DT: 4/6/15@13:54",1428353752,"04/06/2015 @ 13:55",1428353691,"04/06/2015 @ 13:54","#000000","#000000","Y",4
603,50,"T: 101 DT: 4/6/15@13:54",1428354059,"04/06/2015 @ 14:00",1428353696,"04/06/2015 @ 13:54","#000000","#000000","Y",6
605,50,"T: 101 DT: 4/6/15@13:56",1428353845,"04/06/2015 @ 13:57",1428353764,"04/06/2015 @ 13:56","#000000","#000000","Y",5
609,50,"T: 101 DT: 4/6/15@14:01",1428354075,"04/06/2015 @ 14:01",1428354070,"04/06/2015 @ 14:01","#000000","#000000","Y",1
805,50,"T: 101 DT: 4/6/15@14:00",1428354091,"04/06/2015 @ 14:01",1428354058,"04/06/2015 @ 14:00","#000000","#000000","Y",2
809,50,"T: 101 DT: 4/6/15@13:54",1428353700,"04/06/2015 @ 13:55",1428353685,"04/06/2015 @ 13:54","#000000","#000000","Y",2
1003,50,"T: 101 DT: 4/6/15@13:54",1428354059,"04/06/2015 @ 14:00",1428353678,"04/06/2015 @ 13:54","#000000","#000000","Y",7
1005,50,"T: 101 DT: 4/6/15@13:56",1428353848,"04/06/2015 @ 13:57",1428353787,"04/06/2015 @ 13:56","#000000","#000000","Y",5
1007,50,"T: 101 DT: 4/6/15@14:01",1428354099,"04/06/2015 @ 14:01",1428354092,"04/06/2015 @ 14:01","#000000","#000000","Y",1
1009,50,"T: 101 DT: 4/6/15@13:51",1428353829,"04/06/2015 @ 13:57",1428353464,"04/06/2015 @ 13:51","#000000","#000000","Y",12
1021,50,"T: 101 DT: 4/6/15@13:53",1428353580,"04/06/2015 @ 13:53",1428353580,"04/06/2015 @ 13:53","#000000","#000000","N",0
1403,50,"T: 101 DT: 4/6/15@13:53",1428354099,"04/06/2015 @ 14:01",1428353635,"04/06/2015 @ 13:53","#000000","#000000","N",1
1409,50,"T: 101 DT: 4/6/15@13:51",1428354072,"04/06/2015 @ 14:01",1428353481,"04/06/2015 @ 13:51","#000000","#000000","Y",6
1413,50,"T: 101 DT: 4/6/15@13:51",1428354085,"04/06/2015 @ 14:01",1428353488,"04/06/2015 @ 13:51","#000000","#000000","Y",6
1415,50,"T: 101 DT: 4/6/15@13:51",1428353962,"04/06/2015 @ 13:59",1428353464,"04/06/2015 @ 13:51","#000000","#000000","Y",16
1419,50,"T: 101 DT: 4/6/15@13:57",1428354058,"04/06/2015 @ 14:00",1428353854,"04/06/2015 @ 13:57","#000000","#000000","Y",13
1613,50,"T: 101 DT: 4/6/15@13:53",1428353937,"04/06/2015 @ 13:58",1428353584,"04/06/2015 @ 13:53","#000000","#000000","Y",2
1631,50,"T: 101 DT: 4/6/15@13:59",1428353955,"04/06/2015 @ 13:59",1428353955,"04/06/2015 @ 13:59","#000000","#000000","N",0
1707,50,"T: 101 DT: 4/6/15@13:56",1428354052,"04/06/2015 @ 14:00",1428353766,"04/06/2015 @ 13:56","#000000","#000000","Y",3
1711,50,"T: 101 DT: 4/6/15@13:51",1428353475,"04/06/2015 @ 13:51",1428353475,"04/06/2015 @ 13:51","#000000","#000000","N",0
kma371
Just saw this thread. Please submit info to the database in the future.
DB udpdated
