Chevy Silverado 2008 Install
sfd119
Well, I finally got a second to take a picture of my new truck's setup. I'm missing a plate for the console...don't judge ;). I finally got rid of my Stratus (http://forums.radioreference.com/pictures-your-shack-mobile-setup/196796-2005-dodge-stratus-v2.html)
Equipment:
Motorola XTL-2500
Uniden BCD996XT
Uniden BCD996T
Ram Mount console, switches.
Whelen Traffic director for the traffic director in the back.
Whelen Slimlighter for front.
Some Sirennet.com cheap lights for the alley.
Garmin GPS Receiver
Antennas are EMs from WISCOMM: EMFLX-M10001 - Poly Spring VHF/UHF BB Quarter-Wave Roof Mount 108-520 MHz Antenna - ShopWiscomm - Communication Solutions
Yes, I drilled. GPS isn't hooked up yet by the visible serial cable in a few shots ;)
Console:
Close up:
Dark Shot:
Antennas (missing the GPS antenna for the scanners):
aaknitt
Can you pull into your garage with those antennas on the roof? I've been wondering about roof mount antennas for an 07 Silverado but there's not much clearance there to the top of the garage door.
Andy
sfd119
Andy
I have about 7' 5" clearance with the truck and antennas...
KG5KS
Arkansas
Is this a standard, extended or crew cab truck ? Would like to know where you put your wiring and did you take out the factory console / middle seat out ?
Thank you
Kenny
sfd119
Great setup! Probably enjoy it a little more than the Stratus?
A little more room as well ;)
Thank you
Kenny
It is an extended cab truck. I took out the middle seat...it was a pain. You have to take out the Driver & Passenger seats first to get at the center seat. The RAM Mount uses the same holes as it so you have to put that in first before you can put the seats back. If you are planning on doing this...disconnect the battery. Apparently some people have had the air bags go off if you disconnect the sensor under the seat...better safe than sorry.
All the wiring sits inside the console. I have direct power coming from the battery into the cab. From there, both pos and neg are fused and then go into a charge guard (from Havis). From the charge guard, it goes into the MASTER switch and into a RIG RUNNER power distribution. I leave the master on at all times and then let the Charge Guard shut the equipment down automatically after 30minutes (or a low voltage detection), however, I still can shut everything down with the master if the condition warrants it.
JASII
Memory Capacity
Chevrolet Silverado 2008 Installation
I also have a Chevrolet Silverado. but mine is many years older. As an aside, does anybody happen to know if it is still possible to buy vehicles without a center console? For most people the consoles are probably fine, but for amateur radio operators and scanner fans they can be a nuisance. Also, for those that have done sedans with consoles, are they easy to remove from sedans? .
lifsvr25
Northern Wisc
Professional installation, lol
Oh don't let him fool ya, it was done professionally by a auto body shop. I was there for that part of the installation. He definitely fooled alot of the local lawman in the first couple weeks after he got this rig.
Love the antenna installation, really professional look.
Craig
Wiscomm
lindsay34654
North of Tampa Fl
Install
Lets the see install on your car or truck. Does it really matter who did it? he took the time to find someone and have it installed the right way, isn't that what really matters?
