Chevy Tahoe Install Idea's Needed
DTFAudio
Matthews, NC
I have a 2001 Chevy Tahoe. I am looking to install a Uniden BC350C scanner and a CB Radio in the truck. As far as the scanner goes, I am going to remove the tape deck and install the scanner there. As for the CB I have no idea. I'm looking to maintain factory look inside and not put the CB on the side of the center console or anything like that. With the scanner taking up the only hole in the console I'm a little lost on how to mount my CB.
I am looking to add more radio's down the road so I'm thinking I may want to look at a new center console. I wanted to get some ideas from you guys and see if anyone has pictures of this type setup.
DTFAudio
Matthews, NC
Gotcha. I thought about removing the center console as well and installing a 18" Havis Shield C Console with the tunnel mount. I could add back the cup holders and at the same time still mount 3 radios and all my switches.
Drachen_Fire
Center Township, PA
That is always possible. Just double check and make sure there's no amplifier for the stereo attached to the factory center console first.
DTFAudio
Matthews, NC
No amp attached to the center console. Mine is the BOSE system so I have the amp behind the glove box and sub in the rear quarter panel. I need to measure the center console and see how long it is and fine the correct length Havis C Console to go back there with the transmission tunnel mount.
