CHIRP software question "settings"
hotlava646
Houston (Clear Lake), Texas
Trying to program my 5RV2+ and put all my frequencies in. I just downloaded it and it all looks fine, but there are no settings. My main thing to turn off is the ability to transmit. On all the videos I have seen a tab for settings which is where you turn it off. I searched around to see if they moved it, but the only other thing is properties which is not it.
I also wanted to set my screen to show name and not the frequency, but again that was on the setting tab. there is a tab where the settings was and it is called D-STAR for call signs.
Anyone have and suggestions thoughts.
Thank you..............
N4GIX
Hot Springs, AR
Are you certain that you picked UV5R as the radio type? CHIRP supports many different radios, not simply that one...
nd5y
Wichita Falls, TX
Don't rely on YouTube videos. Most of those have bad information.
Did you read the documentation on the Chirp web site?
Documentation - CHIRP
It sounds like the file you are trying to edit isn't an image from the radio. There should be nothing about D-STAR in an image from a Baofeng radio.
SpugEddy
Camden County South Jersey
Yes.
Download from the radio first
Then save the image.
Then edit your frequencies and such
Reupload to the radio
If you want to turn off transmit on certain channels
(or all channels):
In the channels screen, go to the "Duplex" column
Set this option to "Off" you will not be able to transmit on that
channel
Yes.
The D-Star option comes up automatically if you try to create a new file WITHOUT downloading from the radio. If you download from radio before you do edits you'll see the settings tab for your radio.
Don't forget to download the most current version, which as of today is from June 4, 2016 (TODAY).
DickH
... In the channels screen, go to the "Duplex" column
channel
If you want to disable the transmitter on ALL channels:
1. Highlight one freq. row.
2. Press CTRL-A to highlight all rows.
3. Click PROPERTIES. A new window opens.
4. At DUPLEX, change it to OFF, then hit OK.
