I'm trying to find a repeater input/output pair. I have one side of that, not sure if it is the input or output since the user is only licensed for simplex in the first place, but that's not the issue here. (I know, there's a CHIRP forum, but that's a whole other new place for me, please bear with me.)
The radio is a BF UV88, not my favorite but "expendable" here in that I can throw in whatever programming and just use it for exploring without wiping a real radio out of service for a while.
I have the frequency and tone (141.3) that they are supposed to be assigned, and I assume that code is for the repeater input channel.
But if I want to check the likely offsets (5, 6, 9, 10 MHz?) for the repeater output...how do I set CHIRP's DTCS option so that I'm listening for the output, without any tones required? So that I'll get the output, which presumably is not using any tones, without setting my radio to listen only for a non-used tone?
I don't even know if their repeat would be a + or - offset, so I'm presuming that if I scan the four or five most likely offsets, both up and down, I'll be letting the radio scan ten channel settings fairly quickly, in order to try grabbing the one that is being used. And then take that elsewhere.
Or is there a better way to do this?
Rred
Rred
