CHIRP - upload to radio
trx680
Petersburg, Virginia USA
I do believe I connected to my Baofeng f8hp and used the "download from radio" function.
I then typed in a frequency and ofset and tried to "upload to radio" but that function is not highlighted.
What might I be doing wrong?
thanks!!
Will001
SC
Sounds to me like a software problem. I would re-install it, or get the new version they put out frequently.
trx680
Ok
Even though I just loaded it I uninstalled it and reinstalled. Seems to want to work now.
Question:
Where is says Uplink Tone and Downlink Tone 74.4 ---- where do I put that in Chirp?
wyShack
Campbell County, Wyoming
set 'tone mode' to tone then set 'tone' to uplink tone shown. That should provide the tone to the repeater and leave your radio on carrier squelch. My UV-5R does not do well trying to decode tone squelch so I 'leave it off'. If desired you can set "tone mode' to T-SQL and then set both "tone' to uplink and "tone sql" to the 'downlink' down.
good luck and 73
