Those noises are simply the user's radio keying up the repeater, which rebroadcasts the signal. The noise at the end is most likely the radio transmitting a tone that signals that the user is done talking.
As Stated Probably Motorola MDC1200 Digital signaling or GEStar similar Signaling by GE, both can be used by Motorola and other radios. Check here Digital Modes Samples there should be something similar to what you are hearing on there, specifically check MDC1200 and GEstar samples.
