What hoops?
What scanner?
If you are talking about a PSR800 I've found that if you are trying to import a second copy of a TRS that you've already imported into a second scanlist, that won't work. It will only import into the original copy and if you want to do any fancy footwork, you have to import everything into the first, then make copys of the system in question and delete and change scanlists on the copies. Importing will not change anything in a copy made of a system.
