CHP Air Unit Numbers
Dragon911
Air21 appears to be based out of MCC and seems to usually be deployed mostly at night.
Some pix (check out the back seat view!) :
kma371
Seeing N140HP (GA8) flying around Sac area. It's not on our list. I assume it's AIR 23 out of Valley Division, but I can't confirm.
EDIT: Looks like it actually took off from Napa, so maybe it's AIR 31?
By the way the list in the very first post is the most current.
Air37
130HP changed its tail number to 140HP since the aircraft that had before it crashed.
MrAntsy
Sacramento County, CA, USA
Old pictures of H-80 N109HP from a trip to Toro Peak attached (if I did it right)...
kma371
N981HP and N982HP are new CHP helicopters, likely based out of Golden Gate division (based on their flight paths), but unable to pin down their callsigns. I think there is one more out there, but I don't recall the tail number as it's not currently in the air.
Air37
Yes, 981 is the new H-30 and 982 is H-32. 983 is almost done and will be going to Paso. 314 and 341 went south and you should see them in Fullerton
Old post but this isn't one of our GA8s. I believe it was built by Summit Aviation and is in use on the east coast.
kma371
Yes, 981 is the new H-30 and 982 is H-32. 983 is almost done and will be going to Paso. 314 and 341 went south and you should see them in Fullerton.
Thread updated.
Do you happen to have/know the callsigns for the Fullerton and Paso birds?
Air37
979 is currently based out of HQ as a glass cockpit transition trainer and will be going to Redding once 983 is delivered to Paso
Air37
Correction... 976 is out of HQ and going to Redding and 979 is currently in Paso and also going to Redding once 983 is delivered.
ethan1g
Southern Division
Do you know if there are any air-units assigned to Southern Division (like Los Angeles)? I can't seem to find any information on their air units
trufan1
Woah! Haven't logged in a while. Good to see my OP has indeed been popular. :) A quick update; N6197N is now showing that it's registered to a Pleasant Aviation in TX. So, no longer owned by the CHP. I guess it should be removed from the list. On that note, Anyone know where N518HP, is based out of now? It's not in Fullerton anymore. I went to their Air Show and it wasn't there. Their pilot said it was moved up north a long time ago, he didn't specify where though. It's definitely still flying for them though. Still registered and all.
tahoekid77
SF Bay Area
Most likely Auburn
