CHP base antennas
LATA 722
The ones I've seen look like Sinclair SD110 series folded dipoles.
Same type used by CalTrans on their low band system.
vagrant
ker-muhj-uhn
California
I have observed both of those antenna types, or something quite similar on different CHP towers. I think Fresno had the omni and Merced had the folded dipole. I could be confusing the locations though.
vagrant
ker-muhj-uhn
California
Do you recall how much of six it covers, or is it narrow?
Someone loaned me a Cushcraft 6m vertical. I took it down and the guy doesn’t want it back. I forgot the spread on it.
prcguy
Its a little narrow for even a typical 6m repeater split and for the CHP probably sits on one frequency all its life. I was going to rebuild mine with a folded upper element which is known to have wider BW and work fine as a 6m repeater antenna. I have a 6m Ringo also, it covers most of the band just fine but lights up the coax and mast with RF.
